no device detected
hi guys im triying to jailbreak my aplle tv 2 running 6.0.1(6646.80.1). when im trying to create the ipsw seasonpass say : nodevice detected please connect the apple tv via usb to continue. im i little bit confuse because in all the tutorial i saw they normally dont ask to plug the apple tv when doing this step. Anyway i plug the apple tv with the usb cable but same problem … i tryed to plug the usb and the power cable and same problem again…
 i need some hel please !!!
Sorry for my english isn’t my first language…
if the light flashes try a different usb port, then try a different usb cable.
if the light doesn’t flash unless it’s plugged in you have a gen 3
Thank for your fast answer!
first im sure its a gen 2 because i bought it from my friend and i know when he buy it (gen 3 wasnt release) . second i check on the internet how to know if i have a gen 3  or 2 (just to be sure) and it suppose to be a gen 2…
unfortunately, when i buy the apple tv from friend he said that the light dont work anymore (i dont know why but seem to be true because the apple tv work perfecly but no light on)
up for help!!!
