I’ve had all my devices connected to my DS418Play using Webdav for the last 2 years without issue using the synology ddns service. but recently all my remote locations can’t connect anymore and i can’t figure out why
I’ve tried to re-setup as an smb or ftp but i don’t know if im doing it properly in the synology unit and when i try to test it on the documents app for my iphone, it doesn’t connect either
any suggestions or guides? i’ve been searching for the last 2 hrs and it’s driving me crazy
I had an orbi and had all sorts of issues. Ended up going back to my ASUS router and using the orbi in AP mode only. Don’t bother going to the orbi forums. There’s a user FURRYe38 who will spam you with useless info (his fix is to wipe your orbi and start from scratch).
i gave up on the orbi…i factory restored and re-set it up and an hour later was having the same problems, i couldn’t even log in to the router web admin page so i went back to my TP-Link for now
