Synology remote access?
I still have not found a way of using infuse when away from home. FTP does not work with my synology, I can only see the root folders, everything else displays as empty. I have tried using VPN to connect with SMB (even in the latest update) and this does not work. SMB over VPN does work with other video apps like n-player but not here.
Anyone found a way of connecting remotely?
thanks
Hi? Did you try Webdav, I’m using webdav over https and so far so good!
Thanks, trying that now!
WORKS!! Thank you!
Glad I could help :slight_smile:
