Using Plex collections with movies. I’m trying to get e.g. my Star Wars movies in timeline order.
I have the main library in title order. In plex I changed the sort names of the SW movies to “Star Wars A”, “Star Wars B”… . etc. and chose to sort them alphabetically.
But infuse is still showing them in chronological order as they were released.
Is there any way I can get Infuse to “respect” the sorting order I made in the collection in Plex?
duh, just checked it myself. it is broken (again).
@james: You guys fixed the sort order functionality for PLEX collections in Infuse with 6.6.
Running 7.0.5 I just realized that this doesn’t work any longer
Here’s the link to the initial case:
Kind of a bummer; did sth. change logic-wise on the PLEX side of things? Looks like a pretty simple function. Shouldn’t be too tricky to maintain during upcoming releases, I reckon.
Anyhow, help on this matter would be greatly appreciated!
iOS(DID WORK some time ago) Result: Collections sorted by release date (PLEX collection order is not considered)
iPadOS Result: Collections sorted by release date (PLEX collection order is not considered)
macOS Result: Collections sorted by release date (PLEX collection order is not considered)
tvOS(DID WORK w/ Infuse 6.5) Result: Collections sorted by release date (PLEX collection order is not considered)
As mentioned before: It did work for iOS, then you thankfully made it work for tvOS with Infuse 6.5 (see: Plex Collection sort order support - #7 by james) but for whichever reason it has stopped working for all platforms.
(In case it matters: Sort order setting for Infuse is by title for all platforms during my tests)
It would be absolutely fantastic if you can provide a permanent fix for this.
Posting to add that I have the same problem: all collections being sorted by release date, rather than respecting Plex’s sort order.
Specific scenario is that my collections have been created using Plex Meta Manager. On Plex, some collections are sorted by name, some by release date, and some by date added to my library. These rules don’t filter through to Infuse.
Has there been any progress on fixing this? Thanks.
Status Update: For regular PLEX collections, Infuse is now able to differentiate between sort order by release date and alphabetical sort order. That’s two out of three options available in PLEX (cf. my posts above).
@James: Thanks a lot for incorporating this! You should have mentioned that as a fix/feature
@coffeym: The collections you mention are probably smart collections, right? I think Infuse lacks proper support for PLEX smart collections, as far as I know I do know PMM, don’t get me wrong. It’s just that I think technical PMM creates smart collections in PLEX, hence the missing support in Infuse.
@tbor85 Yeah that’s right, all the PMM generated collections I have are smart collections. That explains things! I hope Infuse can incorporate full support for them soon.
Is the fact that “All Movies” on Infuse home screen is not sorted using Plex’s “Sort Title” but by “Title” related to this problem (I don’t want to add posts for nothing)?
