tkhyla
1
Fantastic app but one super bog problem. Is MythTV DLNA supported on Infuse 5?
I see this upnp share but cannot connect to it. Every time come error.
Should this be supported or not? If not, any plan to add it? (should be general DLNA. works ok with other steaming apps)
james
2
If you have a chance, would you mind sending in a quick report and opening a support ticket so we can look into this?
tkhyla
3
report sent via ipad. hope see some logs and get fix for it
thx!
