Hi all!
My first post…
I am running ATV with OS 3.0.2.
ATV Flash 4.1.1 is installed.
There is a Time Capsule configured as a router. An USB hard disk is connected with the TC.
To make sure I can access the USB hard disk I installed AFP support on ATV. It basically works.
But creating a manual sharepoint within the user interface doesn´t work. Nor does the automatic startup.
Therefore I have written a very simple shell script:
mkdir /Volumes/TC_USB
mount_afp -o automount afp://Kernel-TC.local:548/RC3 /Volumes/TC_USB
It mounts one of the USB disks connected with the TC. Startet manually via ssh it works.
Now I would like to see this script launched automatically.
Does anyone know how to do this? Where do I have to anchor it to get it startet after a reboot?
Thanks your your help…
Ali
