AFP Shares - Sorted !!!!
Hello
I bought the aTV Flash at the weekend and I was really disappointed to discover it did not resolve the issue of how to get AFP working.
24 hours on and little sleep I have it up and running and it wasn’t too difficult…
If anyone is still having problems please let me know and I will try and help.
I am running ATV Flash 3.5.1. on a brand new 40 Gb ATV on 2.3.1
Ian.
I’ve tried it but it have not been posible. Did you used the restore 1.0 partition method? Please, help me!!!
A 1.0 restore image is required for setting up AFP. There is no way around this unfortunately.
http://wiki.atvflash.com/index.php?title=Enable_AFP
Hello
I will type up comprehensive instructions over the next day or so and let you all know what I did. I did use some files from a 1.0 image but the files needed are less than 1Mb. Please bear with me.
Ian.
Okay, here goes, I have used these files from a 1.0 dmg.
from sbin directory…
mount_afp
from System>Library>Filesystems…
Appleshare directory and its’ contents.
(If you need them send me a PM, they are about 900K in size)
Please note - To enable write access of the root account, run the following…
sudo -S mount -uw /
sudo -S touch /.readwrite
sudo -S sync
Copy these files to your Apple TV (to the same location)
To create a symbolic link from AppleShare/afpfs.kext to afpfs.fs in /System/Library/Filesystems on Apple TV, run the following command…
cd /System/Library/Filesystems
sudo ln -s AppleShare/afpfs.kext afpfs.fs
To then set owner and permissions, run the following…
sudo chmod -R 755 /System/Library/Filesystems/Appleshare
sudo chmod +x /sbin/mount_afp
sudo chown -R root:wheel /System/Library/Filesystems/AppleShare
sudo chown root:wheel /sbin/mount_afp
sudo chmod +s /System/Library/Filesystems/AppleShare/afpLoad
That works perfectly for me…
Ian :slight_smile:
could you please flick me those files. All i could find in the OS1 image was these afp_mount, afpfs.kext, afpLoad, asp_tcp.kext, check_afp, sshHelper I could find no mount_afp or sbin folder?
or is afp_mount the same as mount_afp
Nevermind show/hide hidden files :slight_smile: duh!
