Hello,
I notice that there is a new parental control on TVOS 17 where you can easily approuve the restriction by saying yes on an iPhone.
Did you check if that system can be used with Infuse? that will drastically simplify my life with the kids …
Hello,
Yes, it works great, everything is fine
Sorry if I was not be clear… Yes it is working today … but what I’m looking is if Infuse will be able to use it to replace the current parental control settings and be more integrating
e.g. validate remotely the view of a movie :->
Yes, there is nothing to be afraid of updating, everything is kept for you
