I have several family members using Infuse on an Apple TV. They are not the most technically minded and I don’t want them to accidentally change settings or metadata.
I previously used the Parental Controls to achieve this and it worked perfectly. Both the main settings menu as well as item edit buttons were protected behind a passcode.
However in a recent update, it appears the search screen has also been protected. I can see the reasoning behind this, but I would still like users to be able to search.
I guess what I’m looking for is some kind of Kiosk Mode. Maybe a quick fix would be to add one extra setting to the Parental Controls where you could choose whether to also restrict the search page or not?
Thanks!
