So I have some files on my Plex which are DV profile 8.1 with dual Dolby Vision with a fallback to HDR. (“Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible”)
If match content range is turns on, Infuse Pro reverts to the comparability HDR layer instead of Dolby Vision. If I force Apple TV to Dolby Vision and turn off match content range, then DV is played but I’m not sure if that’s just the HDR repackaged or true DV.
Any way to fix this or will a future update resolve this? Do I just have to put profile 5 files on my Plex to have native DV support? My NVIDIA SHIELD does not have this problem.
