Hello,
Here is my problem : when I try to play a movie in Infuse that is in Plex it will not play and give this error HTTP 500 (internal server error) :
I have the error on my iPhone as well.
Here is the config and what you need to know :
- Movies are stored on a Mac mini at home
- Tailscale is working fine for other things. I can access my Mac mini files from outside using my iPhone for instance.
- Plex is installed and working just fine on local network
- I can actually use Tailscale and app.plex.tv and I can play movies just fine.
- Internet speed is more than fine.
- I tried using SMB and SFTP (on Tailscale over Internet) so that I don’t have to use Plex but weirdly everything will be fine and then after like 15 min it will endlessly load. I read online that Plex should in theory not have such problems.
I tried to Google stuff but I could not find anything regarding Infuse, Plex, Tailscale, HTTP 500 (internal server error). Maybe I used the wrong keywords but I am a bit desperate.
Thanks a lot in advance.
