Apologies if this is in the wrong place and feel free to move if required, especially if it’s a known issue so I can follow the topic.
My setup is Infuse connected to Plex.
I just grabbed the new movie Plane (2023)
Gerrard Butler and Mike Coulter are the lead actors.
Open in Plex and they’re the first two actors shown.
Open in Infuse and neither are apparently in the movie.
So I obviously wrongly assumed that Infuse just reads the cast and crew info directly from Plex?
EDIT.
Oh right it’s everywhere as apparently neither Brad or Bruce were in Twelve Monkeys.
Lol. Sadly then no lead actor did, as I’m struggling to find any movie that shows a lead actor suddenly.
I’m just more curious of the fact that if Infuse just reads Plex data when connecting that way, why there’s such a huge difference.
Also from what I can see Plex shows the cast in identical order to tmdb and it seems at first glance (but I will have to confirm when I get chance) that Infuse mimics that but misses out the first four or five entries. (So in effect all of the main cast.)
Any thoughts @james
Update. @james
I switched from TestFlight to Stable and all movies corrected themselves immediately. I didn’t even have to clear metadata. I will do anyway and will then reconnect Plex, but in the meantime changing back to TestFlight those changes hold and show correctly.
If I add any more movies over the next few days I will see if it shows the correct cast order.
Thanks for the help.
