I didn’t like the default skin so I installed Ace. Didn’t look good so I wanted to change to another. Problem however that I see no option to go to the setup menu where I can select another skin.
I tried deleting and reinstalling XBMC, looked thru all folders on the aTV (using SSH) to no avail. Each time I reinstall (with restarts and more) the skin Ace keeps appearing. How to get rid of it?
