Hello,
is Infuse able to playback a complete UHd-blu-ray-ISO?
Or is there any workaround how one can do?
Hello,
Yes, Infuse can play full UHD ISO or BDMV files without any conversion.
Playing these files will require an Apple TV 4K.
I have an Apple TV 4K.
Always when I want to start a 4K UHD blu-ray ISO I get an error.
I am in Austria, so the error message is german:
“Ein Fehler ist aufgetreten
Beim Laden des Inhalts ist ein Fehler aufgetreten”
What should I do that it will work?
Other 4K Files also with HDR are playing without problems.
I tried different large ISO files (around 80 - 90 GB), but no one did work. Could you please help me?
If you have a chance, would you mind sending in a quick report from your Apple TV after attempting to play one of these files?
Ok, I sent it by email now.
Hello, i have the same issue on my Apple TV 4k. Server is a COREELEC, connection is wireless (fast). Was there a solution for it ?
Regards
Gooper
