So I installed the Custom Screen Saver Settings plugin through NitoTV today but it appears to be suffering from a bug.
I was able to place my folder with my images in the correct location on my AppleTV with SFTP (private/var/root) however when I go to click “Select Folder” in the custom settings menu… nothing shows up under root. Not even the Media and Library folders are there.
Here are two images to show what I’m talking about…
SSH to the directory and make sure it’s permissions are correct. Fixing permissions should solve this issue, as well as a similar issue many users are experiencing when trying to customize the NitoTV Main Menu Slideshow.
