Is there a way to have the “Find” menu command (and appropriate CMD-F shortcut) work under macOS? I don’t think it’s me, but I’m always ready to be told that the problem exists between the chair and the keyboard when learning new software
Thanks!
Thanks!
3 posts were merged into an existing topic: Command+F (or Option+Command+F) to jump to search field on MacOS
