Yesterday I had two AppleTV, and he was impossible to jailbreak with seas0npass !
But I managed very easily using another tool :
Apple tv 2 ios 5.02 : Use Sn0wbreeze 2.9.6 (Dl on google…), You need original firmware 5.02… Connect the power supply and when the software will ask more connected usb. Let sn0wbreeze create the file on the desktop and using itunes restore selecting it the creates .ipsw (shift + left click). No mistakes, no 3194 !!! After, start appletv and you see directly nitotv… it’s finish !
Apple TV 2 ios 5.1 : Use Sn0wbreeze 2.9.6 (Dl on google…), You need original firmware 5.02… Connect the power supply and when the software will ask more connected usb. Let sn0wbreeze create the file on the desktop and using itunes restore selecting it the creates .ipsw (shift + left click). No mistakes, no 3194 !!! After, start appletv and you see directly nitotv… it’s finish ! the firmware is downgrade…
I hope it works for you all… Sorry for my bad english but i think you understand…
You can use Sn0wbreeze fine, but remember to use tinyumbrella to save your blobs first for it to work,
With the latest version of tinyumbrella i found that i could save the blobs by turning off the request shs from cydia option
Otherwise it will not save them
Then when running sn0wbreeze use ifaith mode and select the blobs you saved with tinyumbrella and let sn0wbreeze do the rest
very easy
Yes this worked for me and i got the error message 3194 i did it 3 days ago i used snowbreeze straight up not using my blobs at all error everytime thought i bricked it so i pluged it into tv and i saw the NITO icon so i loaded all goodies and works like a charm.Why does it work even though it got an error?
