XBMC WON'T QUIT TO RETURN TO ATV MENU
I have installed XBMC but when i try to exit to return to ATV main menu (pressing menu on remote) a vertical bar appears on side while remaining in XBMC. only way to return to main ATV menu is to unplug ATV and restart. anyone else come across this or got a fix ?
What you need to do is dont touch that menu button. You gotta hit the down button till you get to the little square that when you go to it says exit xbmc.
thanks for reply. there isn’t a square that I can see but when i go down two levels it exits anyway (same if you go up it seems). anyway thanks again
Cool glad it worked.
