Help me understand…
Whats the difference between a clean XBMC installation compared to the one provided with aTV Flash?
Another one… i can´t seem to adjust XBMC (provided true aTV) to fit my screen properly, any idéas?
Thanks!
Help me understand…
Thanks!
1.xbmc=xbmc
2.xbmc>system>appearance>zoom
In XBMC did you go to SYSTEM>Settings>System>Video output. Scroll down to Video Calibration and select. It should let you move the frame into view.
