I have XBMC successfully linked to my NAS via SMB on my old 1st gen AppleTV. Has anyone had any success linking this new version of XBMC to an SMB share on the ATV2?
I keep getting an 'operation timed out' error when i input the path/IP manually, or I get an 'invalid argument' error when I go through XBMC's SMB setup 'wizard'
this is good information for those INSIDE the LAN. But what if I am OUTSIDE in the WAN (internet) and want access to my remote server. Need to find some notes on how to set up the PORTS so that we can see this drive location over a WAN, via SMB. have not seen any success stories with that yet.
FYI… The last update on Airport Extreme 5.?? Is causing the ‘operation timed out’ Down grade your firmware to 4.??? It will fix your issue. It did mine.
Just bought 5th Gen Airport Extreme with FW 7.5.2 and am using Airport Utility 5.5.3 i have downloaded several 7.4.2 FW’s and have had no luck. Does anyone have an idea as to what I can do to remedy the situation. Using aTV2 and 1.5 TB Seagate USB HDD on AE. thanks in advance.
