XBMC Nightly Updates - Correct Instructions to Ssh
I had the XBMC nightly build installed on my ATV2.   But I was having a problem with my ATV and apple replaced it with a new one.   Now, for  some reason, I can not get XBMC nightly builds to update on my ATV2.  I’m using the same instruction I previous used, which are:
1. ssh root@(atv ip address)
2. password
3. echo "deb http://apt.saurik.com/ tangelo-3.7 main">/etc/apt/sources.list.d/saurik.list
4. apt-get update
5. apt-get -f install
   (everything works fine until I get to the next item 6:
6. wget http://mirrors.xbmc.org/apt/atv2/deb/
I get the following message:
"  –2011-09-23 17:47:01--  http://hadm.net/xbmc/latest_atv2.deb
Resolving hadm.net… 74.63.212.126
Connecting to hadm.net|74.63.212.126|:80… connected.
HTTP request sent, awaiting response… 404 Not Found
2011-09-23 17:47:02 ERROR 404: Not Found. "
Does anyone know why I’m getting this message?  If this line no longer work, what is the correct code I should enter on for item 6 above?
I also remember downloading nightly build  file from Cyberduck  (http://update.cyberduck.ch/nightly/) and copying the file directly into an ATV2 folder, which allowed me to update from the Maintenance menu.  I can not remember what folder I copied the File into.  Does anyone out there know what folder I should copy the downloaded file?  or give me the correct info to ssh into ATV2?
Thanks.
NEVER MIND… I HAVE RESOLVED THE PROBLEM…
I have gotten this message trying to installXBMC  and trying to install the current nightly build. What doe it mean?
Apple-TV:~ root# E: Could not get lock /var/lib/dpkg/lock - open (35: Resource temporarily unavailable)
-sh: syntax error near unexpected token `(’
Apple-TV:~ root# E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Apple-TV:~ root#
