XBMC is crashing
Hello,
I jail broke my apple tv2 using the untethered method.  I installed nito tv, and through nito tv I installed XBMC with the updatebegone function.  Everything worked fine until last night.  Now when I click on XBMC my screen goes black and the apple tv2 homepage reappears.  Consequently, I can no longer get into XBMC.
Does anyone have any suggestions on how to fix this problem?
Ive already tried the following:
  • updated nito tv
  • removed and re installed XBMC
I have exactly the same problem. Tried to fix it by reinstalling xbmc. Tried even the xbmc nightlies. Nothing helps. I have no clue what causes this.
I found a fix.  Do the following:
-SSH into your apple tv2 via Putty
-log in using your user name and password (default Username: root, default Password: alpine)
-Remove your databases by entering the following code: rm -f /private/var/mobile/Library/Preferences/XBMC/userdata/Database/*db
  This will reset your video database, but the devs are looking into a fix for the DB corruption issue.
-Next reeboot your system using the reeboot command and then exit
Let me know if this works for you?
PS, I got the info from the following link: http://wiki.xbmc.org/index.php?title=XBMC_for_iOS_specific_FAQ#Crashing
worked! thanks a lot!
