An updated version of XBMC is now avalible for download from the following adress:
http://forum.xbmc.org/showthread.php?tid=127369
//HenkeP
//HenkeP
Awesome. Thanks for the info. Works like a charm. No need for 4.4.2 tethered anymore.
thx for the update
testing is runing
Im getting the following error…
Apple-TV:~ root# dpkg -i org.xbmc.xbmc-atv2_11.0-1_iphoneos-arm.deb
(Reading database … 3279 files and directories currently installed.)
Preparing to replace org.xbmc.xbmc-atv2 11.0-0 (using org.xbmc.xbmc-atv2_11.0-1_iphoneos-arm.deb) …
Unpacking replacement org.xbmc.xbmc-atv2 …
dpkg: dependency problems prevent configuration of org.xbmc.xbmc-atv2:
org.xbmc.xbmc-atv2 depends on org.xbmc.xbmc-seatbeltunlock; however:
Package org.xbmc.xbmc-seatbeltunlock is not installed.
dpkg: error processing org.xbmc.xbmc-atv2 (–install):
dependency problems - leaving unconfigured
Errors were encountered while processing:
org.xbmc.xbmc-atv2
Any thoughts?
Fixed it. i did the following before trying to install xbmc for iOS 5.1
echo "deb http://apt.saurik.com/ tangelo-3.7 main">/etc/apt/sources.list.d/saurik.list then do a apt-get update and the install the missing dependencies with apt-get -f install |
Thanks for the update gcastrofm!
how to install this please HELP me :)
cant download it now, the dropbox account is suspended because of the high bandwidth…
Just jail broke Apple firmware 5.0 http://youtu.be/XnCnykP_doA
can someone who downloaded it please upload it to mediafire or another file sharing website?
Remove that media fire link … its outdated … and it would be great to get the feedback in the xbmc forum so i don’t have to monitor this thread here too…
Just uploading it now
sorry, being asked to remove it,
I downloaded the file yesterday - can I use the local copy on my laptop instead of the web address? If so - how??
Cheers
i have downloaded it and it works on 5.1
