XBMC Downloads Menu (Nightlies)
Needs an update to show the new dharma dmg files vs. the old trunk dmg file locations which changed over on the 20th.
You can still download them manually and copy them over but it is more convenient with the download option.
Thank you.
Thanks for the tip.
Update XBMC/Boxee via Maintenance → Manage Plugins to get access to the new builds. :slight_smile:
Thanks for the quick update! :smiley:
