Hello, Im also experiencing major issues with XBMC crashing constantly since moving from the 1.1.1 release to the 1.2, is there a fix, does anyone know why this is happening?
Thanks in advance
Slim
Thanks in advance
Slim
I’m in the same boat. I had it crash several times while I was just trying to correct Metadata…
Same here. After watching movie for 10 minutes, it crash…
Here’s everything i did to get xbmc 90% stable on 1.2
1 - *UNINSTALL MEDIA PLAYER - this thing causes major conflicts, especially with your share connections which will force constant crashes.
2 - *Low powered skin - I recommend Quartz or Rapier
3 - *Disable weather plugins
4 - *Vertical Sync should be either off, or during playback only
5 - Disable library update on startup/Auto update plugin
6 - Disable recently added displays
7 - *Disable RSS feed
Starred items are extra important.
Same problem here… XBMC blinks then the screen goes black forever. It happens randomly
