XBMC/APTV Question....
Recently received an APTV with XBMC pre-installed… Everything was working ok; up until today! Without getting into all the detail: I ask everyone; how can I delete everything on my XBMC (including settings; files; etc)? If I do a factory re-set of the APTV will I lose the XBMC program? Is there a way in the XBMC settings to accomplish this as well? Bottom line: I need to start completely over.
Thxs in advance!!
A factory reset will remove everything that is currently installed on the AppleTV (apps, media, settings etc). If you want to start over, this will give you a clean slate.
