XBMC and ITUNES
just a simple question…
Can I see my Itunes library sync on an external drive with XBMC?
I have tried to import using Itunes plugin but it does not work
Anyone can help??
XBMC can’t pull an iTunes playlist from another computer directly. One workaround is to pipe it through the FireFly media server. See this :
http://forum.xbmc.org/showthread.php?t=31683
I just set this up and it sort of works - I’m having an issue with library, but I can pull my playlist in and view it and play it through Music > Files with no problems …
