xbmc and airport extreme 7.5.2
If you stream files from a usb disk connected to the airport extreme to the apple tv and xbmc, well, don't upgrade to 7.5.2;
after I did it xbmc could not see anymore my disk connected to ae.
Had to downgrade….
Anyone else experienced it?
Bump
I don’t have a problem with it, did you use an ip address to add the source,
Prephaps when you updated your airport, the ip address for the hard drive changed.
Do you have the problem where your hard drive goes to sleep, and you have to go on your computer to wake it up
