X256 UHD HDR 10bit?
Hi guys.
Can the ATV4K + Infuse do the above? Streaming from my local server (LAN)?
Yep! :slight_smile:
Well that’s promising, considering I can’t stream x265/HDR 10bit through Plex/XboxOne.
Now apple,. hurry up with Atmos passthrough.
Were you able to get it to work on your ATV 4K? Because I get 8bit output for 10bit files.
It has been always working for me. Or at least I think so, the 10 bits HEVC movies I have do look somehow better to me than the 8 bits versions. Like smoother. How do you check the bits output, with the HUD in the Developer Options?
