X-callback-url not working
I’ve been experimenting with the save action (“Bookmark a video URL in Infuse to play later”) at API for Third-Party Apps & Services – Firecore Support, calling it like so:
infuse://x-callback-url/save?url=https://my-url
The link is added to Infuse just fine, but Infuse is unable to play the actual file. It displays the following error:
An error occurred
Failed to open input stream in demuxing stream
If I simply paste the URL directly into Infuse from the “Add Files > via Direct URL” section, the same URL plays perfectly fine.
It doesn’t matter if I encode the URL or not, using the x-callback-url syntax from the documentation only allows the link to be created, but not actually played.
I think this a newish feature, so probably just a snag on the way out the door, so to speak.
Could someone have a look at this?
For reference, this is me attempting to play a file added: WM8FZ
Feel free to use that file for testing (if visible from the debug log); it’ll be available for at least a couple more weeks.
Edit:
This is me adding the same URL directly to Infuse and then playing it for a couple seconds (successfully): 587S1
This is appears to be a long URL with many variables (? or & symbols), so this will not work unless you fully encode the URL before using it with the API features.
If I encode your URL and use that it’s working for me here.
I sent you a PM with a URL snippet you can copy and paste into your browser.
To provide some context, I was using Apple’s Shortcuts app to build a Shortcut. The app provides a URL Encode/Decode action, but it unfortunately does not encode the beginning parts of a URL.
For example, if provided:
https://foo.com/bar?hi=1
It will encode that to:
https://foo.com/bar%3Fhi%3D1
Which neglects to encode the protocol and path characters, so it should look like this:
https%3A%2F%2Ffoo.com%2Fbar%3Fhi%3D1
That last URL is what Infuse requires. Notice that even the protocol slashes and path slashes after the domain are encoded.
Thank you for the help James! I will be manually replacing characters to accomplish what I need.
