This topic was closed:
https://community.firecore.com/t/wrong-metadata-language/40590/36
But the problem remains the same.
Will this bug EVER be fixed, so that I can enjoy Norwegian metadata language for TV shows?
I note that this topic has now been removed from the list of planned fixes. Unbelievable that such an easy bug to fix is not just dealt with once and for all.
Why not just do it the way TMDB does it? Can it be so hard?
I suggest that Infuse should now remove Norwegian from the supported languages list.
Anything new about this?
