Wrong metadata for Midnight diner
I’m having trouble with the tv show “Midnight diner: Tokyo stories”.
If you check thetvdb, there are three possible matches
  • Late Night Restaurant, show ID 297974
  • Midnight diner, show ID 229011
  • Midnight diner: Tokyo stories, show ID 318759
Infuse takes the second option, no matter what I try. How can I make it choose the third option? The colon in the show name is probably causing difficulties…
Thanks!
Martijn
Have you tried using the Edit option in Infuse to select an alternate title?
Thanks James! This works indeed.
I didn’t try it earlier because I thought the change would not be synced across devices. It is synced however, so this solves my issue.
