My Infuse Pro can’t correctly show the right metadata of the episode 0 of this show (https://www.thetvdb.com/series/the-next-generation-patlabor/seasons/1). And instead, it pulls a wrong metadata from TMDb which shows it as a movie.
Can you provide the exact file name you have for episode 0?
The majority of tv shows start with episode 1 not 0 so this may be an issue.
The exact file name is: The.Next.Generation.Patlabor.S01E00
Thanks!
