Wrong Metadata for Columbo
Hi, years ago when I was a newbie there was an issue with Columbo as I’d forgotten to add the S for the season. However that was resolved thanks to members here and everything showed correctly.
Recently I’m having a problem. For example the first episode is labeled correctly - Columbo S01E01 Prescription Murder but it shows the wrong metadata and recognizes the episode as Murder by the book. Would appreciate any help as to why this is happening. The other shows are in proper order. Thank you.
It looks like Murder by the Book is the correct info for S01E01
For “Prescription Murder” (which appears to be a special episode) the file should be labled “Columbo S00E01 Prescription Murder” so “S00” instead of “S01”.
Thank you, will change the names, can I request you to let me know the source, so I can make the changes for all the episodes. I’ve been using filebot, which I think uses the TVDB website.
Infuse uses tmdb for both movie and tv metadata.
I linked directly to the columbo pages in my response above. Infuse uses TMDB for both Movie and TV series metadata. :wink:
Thank you, didn’t realize you’d linked to the source. Will make the changes accordingly.
