wrong MediaPlayer sorting
The sorting in the Media Player list view is based on the filename which is sometimes very annoying.
I’m german thus i use the german titles but sometimes the metadata cannot be found. If i then choose the title of the production country (most of the time US but sometimes FR/CA) the german title can be found.
Example: “Die Akte.avi” and no metadate can be found. “The Pelican Brief” metadata in german can be found!
Problem: File is now listed below movies like “Stone” or directly above “TRON” and not below D(ie) or at least A(kte).
Intended: Sorting should be done by metadata NOT by filename (or add an sort option)!
Thanks :slight_smile:
Yes add an sort option.
I want to sort my content on date instead name
