Wrong language on subtitles
I keep noticing that infuse on Apple TV is not picking the correct language on subtitles.
I use Hebrew subtitles. I also like English when Hebrew is not available. Many titles contain Hebrew and some have external files in Hebrew.
Regardless, in many cases a seemingly random language is selected for me.
There should be a way to select the requested language and show if it exists (plus a secondary lang) and nothing else.
What do you have selected in the Infuse settings under Language > Subtitles?
the top menus have Auto and English (Israel) listed.
But Hebrew is what is checked on.
I think that in previous versions I could check more than one language and prioritize them as well, but even Hebrew as the default is good. However, it sometimes works and sometimes not.
Why not try selecting Hebrew instead of Auto for subtitles?
As I wrote. Hebrew is what is checked on.
It’s in the middle of the list, not on top.
Just was going by this
And when I select Hebrew it shows in the settings for subtitles.
This is how it is set for me. Exactly
Just watched a tv show that has built in Hebrew subtitles. It showed the Greek ones (which are one above the Hebrew on the list). I had to manually switch to Hebrew.
You may want to run that show through media info and post the results here if the subs are internal.
Did you download the subs and are they a separate file? How is that file named?
Subs are internal. Here is media info:
General
Unique ID                                : 250076192734422828668197304455467157949 (0xBC22EC3C652CE26109100AC0C928C9BD)
Complete name                            : V:\finished\download\Swagger\Season 2\Swagger.S02E06.HDR.2160p.WEB.H265-SuccessfulCrab[TGx].mkv
Format                                   : Matroska
Format version                           : Version 4
File size                                : 9.83 GiB
Duration                                 : 55 min 24 s
Overall bit rate                         : 25.4 Mb/s
Writing application                      : mkvmerge v77.0 ('Elemental') 64-bit
Writing library                          : libebml v1.4.4 + libmatroska v1.7.1
Video
Format                                   : HEVC
Format/Info                              : High Efficiency Video Coding
Format profile                           : Main 10@L5@High
HDR format                               : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile B compatible
Codec ID                                 : V_MPEGH/ISO/HEVC
Bit rate                                 : 24.1 Mb/s
Width                                    : 3 840 pixels
Height                                   : 1 920 pixels
Display aspect ratio                     : 2.000
Frame rate mode                          : Constant
Frame rate                               : 23.976 (24000/1001) FPS
Color space                              : YUV
Chroma subsampling                       : 4:2:0 (Type 2)
Bit depth                                : 10 bits
Bits/(Pixel*Frame)                       : 0.137
Stream size                              : 9.34 GiB (95%)
Language                                 : English
Default                                  : Yes
Forced                                   : No
Color range                              : Limited
Color primaries                          : BT.2020
Transfer characteristics                 : PQ
Matrix coefficients                      : BT.2020 non-constant
Mastering display color primaries        : Display P3
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 2047 cd/m2
Maximum Frame-Average Light Level        : 177 cd/m2
Audio
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : A_EAC3
Bit rate mode                            : Constant
Bit rate                                 : 768 kb/s
Channel(s)                               : 6 channels
Channel layout                           : L R C LFE Ls Rs
Sampling rate                            : 48.0 kHz
Frame rate                               : 31.250 FPS (1536 SPF)
Compression mode                         : Lossy
Stream size                              : 304 MiB (3%)
Language                                 : English
Service kind                             : Complete Main
Default                                  : Yes
Forced                                   : No
Complexity index                         : 16
Number of dynamic objects                : 15
Bed channel count                        : 1 channel
Bed channel configuration                : LFE
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : English
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
Format                                   : UTF-8
Title                                    : English [SDH]
Language                                 : English
Default                                  : No
Forced                                   : No
Text #3
Format                                   : UTF-8
Title                                    : Arabic
Language                                 : Arabic
Default                                  : No
Forced                                   : No
Text #4
Format                                   : UTF-8
Title                                    : Bulgarian
Language                                 : Bulgarian
Default                                  : No
Forced                                   : No
Text #5
Format                                   : UTF-8
Title                                    : Chinese Simplified
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #6
Format                                   : UTF-8
Title                                    : Chinese Traditional
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #7
Format                                   : UTF-8
Title                                    : Chinese Yue
Language                                 : Chinese
Default                                  : No
Forced                                   : No
Text #8
Format                                   : UTF-8
Title                                    : Czech
Language                                 : Czech
Default                                  : No
Forced                                   : No
Text #9
Format                                   : UTF-8
Title                                    : Danish
Language                                 : Danish
Default                                  : No
Forced                                   : No
Text #10
Format                                   : UTF-8
Title                                    : Dutch
Language                                 : Dutch
Default                                  : No
Forced                                   : No
Text #11
Format                                   : UTF-8
Title                                    : Estonian
Language                                 : Estonian
Default                                  : No
Forced                                   : No
Text #12
Format                                   : UTF-8
Title                                    : European Spanish
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Text #13
Format                                   : UTF-8
Title                                    : Finnish
Language                                 : Finnish
Default                                  : No
Forced                                   : No
Text #14
Format                                   : UTF-8
Title                                    : French
Language                                 : French
Default                                  : No
Forced                                   : No
Text #15
Format                                   : UTF-8
Title                                    : French Canadian
Language                                 : French
Default                                  : No
Forced                                   : No
Text #16
Format                                   : UTF-8
Title                                    : German
Language                                 : German
Default                                  : No
Forced                                   : No
Text #17
Format                                   : UTF-8
Title                                    : Greek
Language                                 : Greek
Default                                  : No
Forced                                   : No
Text #18
Format                                   : UTF-8
Title                                    : Hebrew
Language                                 : Hebrew
Default                                  : No
Forced                                   : No
Text #19
Format                                   : UTF-8
Title                                    : Hindi
Language                                 : Hindi
Default                                  : No
Forced                                   : No
Text #20
Format                                   : UTF-8
Title                                    : Hungarian
Language                                 : Hungarian
Default                                  : No
Forced                                   : No
Text #21
Format                                   : UTF-8
Title                                    : Indonesian
Language                                 : Indonesian
Default                                  : No
Forced                                   : No
Text #22
Format                                   : UTF-8
Title                                    : Italian
Language                                 : Italian
Default                                  : No
Forced                                   : No
Text #23
Format                                   : UTF-8
Title                                    : Japanese
Language                                 : Japanese
Default                                  : No
Forced                                   : No
Text #24
Format                                   : UTF-8
Title                                    : Korean
Language                                 : Korean
Default                                  : No
Forced                                   : No
Text #25
Format                                   : UTF-8
Title                                    : Latin America Spanish
Language                                 : Spanish
Default                                  : No
Forced                                   : No
Text #26
Format                                   : UTF-8
Title                                    : Latvian
Language                                 : Latvian
Default                                  : No
Forced                                   : No
Text #27
Format                                   : UTF-8
Title                                    : Lithuanian
Language                                 : Lithuanian
Default                                  : No
Forced                                   : No
Text #28
Format                                   : UTF-8
Title                                    : Malay
Language                                 : Malay
Default                                  : No
Forced                                   : No
Text #29
Format                                   : UTF-8
Title                                    : Norwegian
Language                                 : Norwegian
Default                                  : No
Forced                                   : No
Text #30
Format                                   : UTF-8
Title                                    : Polish
Language                                 : Polish
Default                                  : No
Forced                                   : No
Text #31
Format                                   : UTF-8
Title                                    : Portuguese
Language                                 : Portuguese
Default                                  : No
Forced                                   : No
Text #32
Format                                   : UTF-8
Title                                    : Portuguese Brazilian
Default                                  : No
Forced                                   : No
Text #33
Format                                   : UTF-8
Title                                    : Russian
Language                                 : Russian
Default                                  : No
Forced                                   : No
Text #34
Format                                   : UTF-8
Title                                    : Slovak
Language                                 : Slovak
Default                                  : No
Forced                                   : No
Text #35
Format                                   : UTF-8
Title                                    : Slovenian
Language                                 : Slovenian
Default                                  : No
Forced                                   : No
Text #36
Format                                   : UTF-8
Title                                    : Swedish
Language                                 : Swedish
Default                                  : No
Forced                                   : No
Text #37
Format                                   : UTF-8
Title                                    : Tamil
Language                                 : Tamil
Default                                  : No
Forced                                   : No
Text #38
Format                                   : UTF-8
Title                                    : Telugu
Language                                 : Telugu
Default                                  : No
Forced                                   : No
Text #39
Format                                   : UTF-8
Title                                    : Thai
Language                                 : Thai
Default                                  : No
Forced                                   : No
Text #40
Format                                   : UTF-8
Title                                    : Turkish
Language                                 : Turkish
Default                                  : No
Forced                                   : No
Text #41
Format                                   : UTF-8
Title                                    : Ukrainian
Language                                 : Ukrainian
Default                                  : No
Forced                                   : No
Text #42
Format                                   : UTF-8
Title                                    : Vietnamese
Language                                 : Vietnamese
Default                                  : No
Forced                                   : No
Specifically in response to this, I briefly had a theory that Infuse saw the ISO-639 language code “he” and assumed “Hellenic” :slightly_smiling_face::upside_down_face:
Nope. On this one it plays the Hungarian subtitles…
Maybe the different spelling of Hebrew is at fault?
