Wrong keyboard setting: english instead of german
On my mac the keyboard is set to german and it works for all applications except the MirRow apps in Front Row. There I have the US keyboard settings. As not only "z" and "y" are interchanged but also all special characters are competelly different (inclusive "." and "/"), this is quite anoying. Entering a web adress ends up in try-and-error-session until the correct sign is found.
Is this a known issue? Do other users observe the same?
Can the keyboard setting for MiRow be changed somehow?
If not, I would suggest to implement this in the settings in the next version or make it take over the system settings.
Problem solved with new version 1.0.2.
