nothing seems to want to update thru the maintenance icon. the update all has a blue circle that keeps spinning around and around. when i do try to update things like xbmc, nitotv and even maintenance i get installation failed! then is says retry installation or view log. i go to view log and it says E:dpkg was interrupted, your must manually run ‘dpkg --configure -a’ to correct the problem. im not to sure what that means or how to do it. is there an easy fix?
Same situation here. I also tried installing the latest flash thru my computer and the latest flash dmg, but still same situation.
Hmm, would you mind sending in a bug report so we can look into what’s going on?
