This isn’t actually a big deal as I so rarely use Infuse on my MacBook but Im also curious to the reason and if anyone has the answer.
WOL is configured in Infuse with the MAC address in the advanced settings for my share, the same settings are mirrored on my iPhone 13 mini, my wife’s iPhone 13 mini and my two Apple TV’s, all of those devices wake up my file server perfectly and as expected.
For some reason however opening the MacOS version of Infuse does not wake up my fileserver, I’m not even sure if Infuse itself is the issue, perhaps some sort of privacy setting on the MacOS itself or network config?
After investigating the iCloud sync issue on my MacBook I was facing… I was screwing around with enough of the settings that I also fixed this.
Seems at least for me to get WOL to work from a MacBook (in my case MacBook Pro) Infuse needs to have Full Disk Access. Now I expect you can probably enable a more limited setting but enabling this one now means my Mac wakes up my server. I expect I forgot to set it when I first installed Infuse or its not there by default, after toggling it on in Security and Privacy settings it solved this.
