Window stuck in wide aspect ratio and unable to be adjusted?
When using Infuse on the Vision Pro, you cannot adjust the aspect ratio of the window. When browsing the library, it is stuck in a 21 to 9 aspect ratio. You can resize the window, but it gets stuck in that aspect ratio.
Yes, that’s really annoying. Please fix this issue.
you may want to provide both Infuse version numbers and OS versions.
Newest versions:
8.3.2
26.1
I should have included the version numbers in my original post. It’s been since 8.3 and VisionOS 26 for me. Still that way on the latest versions (8.3.2 and 26.1).
Annoying bug please correct it fast :folded_hands:t2:
What shape are you hoping to have?
Many other apps (including the Apple TV app) have a fixed aspect ratio.
I think it was not a fixed ratio before (no ?) but that we could choose the size moving the low-right corner :man_shrugging:t2:
And if it was a fixed ration (I dont remember) it should not be a 21/9 one, to large and too thin
The ratio has been fixed since the original Infuse 8.0 release last year. It should match the ratio you see in the Apple TV app.
Something has changed about the ratio in the two last version. Difficult to compare now but it’s not good as it was.
(I am not alone to find this problem)
Infuse on Vision Pro on the left, Infuse on Apple TV on the right
:man_shrugging:t2:
Hmm this is different than what I’m seeing here.
Which version of visionOS are you on?
Infuse 8.3.3?
Yes 8.3.3 (5449) on Vision Pro and this is the ratio you can see on the photo and you can’t change anymore even in the main windows where movies choice is available (start window). So we must always scroll up and down to see informations.
Hope it helps.
Same problem with 8.3.4 version
I can confirm the same issue on my Vision pro even on the latest build and latest beta of Vision os.
A post was merged into an existing topic: HDR looks Flat on Vision Pro in Immersive (elevated blacks)
I tried to trash the Vision Pro Infuse App and to reinstall it and now the ration came back to OK. (as the Apple TV version)
Thanks for sharing this info. This is helpful to know.
Thanks to you ! Hope it helps.
