Will not show movie picture
since one week Infuse will show following movie picture when I add new movies.
Can someone tell me why Infuse will show this picture instead of the correct movie picture?
Do you have Embedded Metadata turned on in settings?
Also, do you have that as a artwork file in any of the folders you’re using?
I have checked the folders but there no artwork file which looks like this.
What I have done is, I deactivated Embedded Metadata. Deleted the Metadata database and scanned again. Now infuse shows the correct movie picture.
Who ever encoded must have used this as the embedded poster for those movies. You should be good to go without the Embedded Metadata turned off. It will also slow down the scans in Infuse when you have it turned on so it’s a win/win fix.
