will itunes sync .avi flies to appleTV
I`v got all my .avi movies files in itune will they sync to appleTV after puting aTV Flash on it or do they have to be saved as a reference file still
iTunes will only sync h.264 m4v or mp4 files. Apple only wants you to use their type of files. You can transfer your AVI files using Fugu or CyberDuck on the Mac or WinSCP on Windows and move them into the Movies folder on the Apple TV. You can check it out here:
http://wiki.atvflash.com/index.php?title=SSH
