I tried several videos with dolby vision resulting in black screen with audio only.
If theres no plan of supporting dv, is it possible to just export video in the normal hdr10 format in the future?
This has been on our radar, but the feedback we have received so far from Dolby seem to indicate the Apple TV does not support dual-layer DV video at this time. Dual-layer DV is what is used for UHD Blu-ray titles, and is an example of the most practical real-world use case for DV in an app like Infuse. However, dual track DV is backwards compatible with HDR10 - so when these are played in Infuse it will gracefully fallback to HDR10 without any fuss.
There is also a single-layer DV variant, though this is typically used in streaming applications and AFAIK isn’t available for local libraries.
Though I’m curious, what type of files do you have? Would you be able/willing to send in a sample we could review here?
It seems that this is more like a single video track file with DV rather than a double track one.
General
Complete name : 2017_OLED_Dolby+Vision全景声演示片_4K.mp4
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42/dby1/isom)
File size : 260 MiB
Duration : 1 min 18 s
Overall bit rate : 27.7 Mb/s
Encoded date : UTC 2017-04-13 21:56:52
Tagged date : UTC 2017-04-13 21:56:52
Video
Format : HEVC
Format profile : Main 10@L5.1@Main
Dolby Vision : 1.0, dvhe.stn@uhd60, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Bit rate : 27.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 59.940 (60000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.054
Stream size : 254 MiB (98%)
Audio
Format : E-AC-3
Format/Info : Enhanced Audio Coding 3
Format profile : E-AC-3+Atmos / E-AC-3
Codec ID : ec-3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 13 objects / 6 channels
Channel positions : 13 objects / Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 187.500 FPS (256 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 6.00 MiB (2%)
Service kind : Complete Main
I’ve managed to upload one finally so please test if if interested.
Thanks!
Hi, I got a few 1:1 iso from UHD 4K Dolby Vision discs, as Gladiator, Save Private Ryan etc. Played in infuse pro on APTV 4K latest firmware 11.4
They open and play very smooth but no Dolby Vision, only HDR.
Any hope to have DV from your excellent app?
Thank you
No.
Unfortunately Tim is correct.
The Apple TV does not support dual-layer DV, and per our conversations with Dolby there is no way to add it at this time.
Sorry.
Thank you
