I’ve got my TVSeries folder on my NAS which contains TV series like Family Guy, Modern Family etc. Every season has a folder, and a folder contains episodes, usually .mkv files. Infuse usually finds the correct metadata for these series.
But… i also have folders for series which contain bluray discs only… e.g. Breaking Bad. Breaking Bad has also folders for each season, and each seasonfolder contains 3 or 4 bluray .iso files or BDMV folders… Infuse refuses to find any metadata for these series… Why is that?
Unfortunately, Infuse does not currently support fetching metadata for single items which contain multiple episodes, but this is something we have on our radar to look into for the future.
If it was only possible to ‘edit’ the metadata for the folder and subfolders (like in case of faulty tv series) so i could manually set it to the series i want, that would be something…
I have this issue as well. I get the series artwork OK, but grey blank artwork for the Season folder and random artwork for each of the disc folders within it.
My structure would be as follows, each level being a folder on the NAS:
TV Series Name (correct Artwork)
Season 1 (blank grey artwork)
Disc 1 (random artwork with Disc 1 in name)
AVCHD (folder containing the BDMV and Certificate folders)
Disc 2 (random artwork with Disc 2 in name)
Season 2 (blank grey artwork)
Would a .jpg file in the appropriate folder provide the artwork needed and a custom .xml file to provide descriptive metadata if the top level Season folders were set to use local metadata?
