Why do some shows get label tv on iOS and not tvOS?
So mandalorian and Obi-Wan show up as tv shows on iOS but they show up as other on tvOS and there’s no way to move them.
Is this a bug or is there a reason infuse does things differently between the two operating systems?
Thanks and I apologize in advance if this is a stupid question.
How do you have the files named?
Also, if you have iCloud sync turned on it should match on all devices if you had to correct one.
Also, you should let the ATV finish it’s scan and sync then they should all be in the right sections. :wink:
I won’t go into details, the naming is indeed questionable. I totally understand this type of naming causes problems. My immediate thought was the sloppy naming. iCloud sync is enabled across devices. Once I saw one device got the category right and not the other, I ruled out the naming. When I get home I will try again the sync again, if that doesn’t work then I will properly name it. I appreciate your reply and I will update my post once I try your suggestions.
