White border around episodes images
On Infuse for iPhone and iPad i notice a white border around Tv Series episode selected at the moment. It moves when another episode is selected.
I think it’s graphic bug.
Which version of macOS are you using?
I’m using macOS 13.2.1 and iPadOS 16.4, both with the same graphic glitch
@james Any news about this issue? I see the same thing in the last release, 7.5.2. Am i the only one to see this graphic glitch?
I wasn’t able to replicate this here in a few quick tests.
Are you in Dark Mode full time, or are you switching back and forth between light and dark?
If switching, are you able to isolate when the white border appears? EG Infuse is open when the switch from light to dark happens, and then the border appears.
I use dark mode full time, the border is shown every time i open the app and it doesn’t disappear
Is this affecting all TV shows, or just a few? What about movies?
Are you using a media server like Emby, Jellyfin, or Plex?
Any sort of manual artwork for the affected files?
Would you mind sending in a report from your device (and post the 5 digit code here)?
FWIW, this is a screenshot form my MBP with macOS 13.3.1 and Infuse 7.5.2.
It affects all TV shows.
It doesn’t affect movies because there isn’t a list of episodes.
I use a SMB connection from a NAS. Every item in my list uses manual artwork.
If i change from settings aspect color from dark to white, and then come back to dark mode, the white board isn’t shown, but it appears again when i close ad reopen the app.
This is the diagnostic code: 4YZPM
UPDATE: @james It seems white borders appear when a TV series is opened from home (for example from recently added list) and it doesn’t appear if i open a TV series from “File” section
