Where is Volume Boost?
Hey team
LOVING Infuse 2! Great interface and it works perfectly. However, I can’t seem to find the volume boost function. Am I just completely missing it, or is this just in the Pro version?
Thanks!
Rex
The Volume Boost option can be found in the Audio tab of the Playback Settings menu (tap gear icon while a video is playing).
Oh, interesting. That option is not available to me (see attached).
Any ideas? I’m on iPad 2.
Thanks for the quick reply!
Can you upload a screenshot of the audio track type?
Some audio track types aren’t eligible for boost the current version.
Sure, is this what you need?
Thanks.
Was this video synced through iTunes by chance?
Unfortunately some features aren’t available for synced videos.
Yes, actually! I’ve uploaded a file through the browser and that solved the problem.
Thanks a lot for the speedy solution. Great app.
Great! :slight_smile:
A post was split to a new topic: Where is volume boost on tvOS Infuse
