Where is ScreenSaverEngine?
Hi there,
I recently upgraded my XBMC install from 9.04.1 to 9.11 beta 1 and every time when I launch XBMC i get a prompt asking me ‘Where is ScreenSaverEngine?’
Has anyone else experienced this or even better come up with a solution as it’s frustrating to have to use Screen Sharing every time to dismiss this dialog box.
Thanks,
Andrew
Turns out it’s a bug in Beta 1
http://xbmc.org/trac/changeset/24966/
And the temporary fix is either revert back to the previous version or this as listed on XBMC support site.
Seems that nitoTV installer is to blame for this issue, it adds AppleScript.framework, renaming it solves the issue.
So, if you are brave enough, you can ssh in to ATV and :
Quote:
sudo mv /Volumes/OSBoot/System/Library/PrivateFrameworks/AppleScript.framework /Volumes/OSBoot/System/Library/PrivateFrameworks/AppleScript.framework_bak
next time you start XBMC there will be no prompt to chose ScreenSaverEngine
Zeljko
That’s worked a treat, thanks!
