Where does Infuse get metadata tags such as resolution and audio format?
I host my movie library on a Mac via SMB and have the favorite folder using TMDB metadata. Where does Infuse get tags like 4K, HDR, Atmos, etc.? And is there a way to override or add specific tags without converting the folder to use Local metadata?
resolution and audio info are pulled directly from the file as well as duration.
