When trying to add emby server keeps on saying username and password isn't right even when the same creds work on my pc
I am trying to add a emby server with infuse on my apple tv 4. After completing the pin sign in it lists the servers on my account and after selecting the server i would like to add then pressing save it says “Checking connection” and then says “Your username and password combination isn’t right. Please try again.” I have tryed multipul times trying to use the pin to sign if from multipul devices and none of them made it work
Is this still happening with the latest 6.4.4 update that was released yesterday?
If so, can you send in a report form your Apple TV via Infuse > Settings > Submit Diagnostics and post the 5 digit code it gives you here?
sorry i vanished for a bit, it no longer says the user and pass is wrong however it says “unexpected server response. please try again.”
Hello I have the same issues on my apple tv, ipad works fine.
I get an unexpected server error when using emby pin, and connecting with username and password gives wrong password error.
My diagnostic code: R8D0A
This should be resolved in 6.4.5 which was released earlier this week.
Thanks for your patience.
